175
Reg: Upgrading Project from Version 11.1.20111.2064 to Version 13.1.20131.1001(Aikido Framework) of Infragistics
Hi Infragistics Team,
We are presently using Infragistics controls of Version 11.1.20111.2064 in our Project.
No we are planning to upgrade our product to Aikido frame work (Version 13.1.20131.1001).
Presently the below are list of dlls we are referring in our project:
Infragistics.Web
Infragistics.WebUI.Misc
Infragistics.WebUI.Shared
Infragistics.WebUI.UltraWebChart
Infragistics.WebUI.UltraWebGrid
Infragistics.WebUI.UltraWebListbar
Infragistics.WebUI.UltraWebNavigator
Infragistics.WebUI.UltraWebTab
Infragistics.WebUI.UltraWebToolbar
Infragistics.WebUI.WebCombo
Infragistics.WebUI.WebDataInput
Infragistics.WebUI.WebHtmlEditor
Infragistics.WebUI.WebNavBar
Infragistics.WebUI.WebSchedule
List of dlls which are not available from Aikido frame work:
  • Infragistics.WebUI.UltraWebGrid
  • Infragistics.WebUI.UltraWebListbar
  • Infragistics.WebUI.UltraWebNavigator
  • Infragistics.WebUI.UltraWebTab
  • Infragistics.WebUI.UltraWebToolbar
  • Infragistics.WebUI.WebCombo
  • Infragistics.WebUI.WebNavBar
Problem we are facing is that we are not able to find all the dlls required in the latest Aikido Version frame work.
For Example:WebPanel is the class which is avaialable under - Infragistics.WebUI.Misc.dll
But in the Aikido framework (Infragistics4.WebUI.Misc.v13.1)dll, we are not able to find WebPanel class
Questions:
1)      For this we need to know from where / workaround can be available for the missing dlls ie., does in any other namespaces will these available or not?
2)      Does the available dlls will solve our requirements? ie., does the latest available Aikido dlls contains all the available classes/methods same as previous?
3)      In order to use these Aikido frame work what kind of changes are needed for solution ie., config changes, style sheet changes, skin changes, kind of new methods that we need to refer instead of existing methods?
4)      As we are getting these errors in designer files, Do we need to update any kind of licensing files in order to reflect the latest references.
5)      Need any other combination of dlls with the existing dlls which will solve my issue?
We are using VS 2012 for development purpose, and we are not using any Version Utility Upgrade Tool for Upgrading our Project.
We are maintaining a local repository (kind of LIB folder) which we will refer the dlls for our Project.
Please let me know if I can provide you any other furhter information which will help you in Understanding our issue further.
Thanks in Advance.
Thanks & Regards,
Rajkumar Uppala
