2715
Error when exporting report
When I try to export a html5 report i get this error
404 - File or directory not found
the url is this
http://arosweb/22339eaa-ec0c-4c40-982e-56a9f750d337/XLS.1.True.igrResource
the report display fine
it is a html5 report in a webform
I use ver. 2013.1 with lastes SR
<%@ Page Language="vb" AutoEventWireup="false" MasterPageFile="~/Site.Master" CodeBehind="Teknisk_Liste.aspx.vb" Inherits="Intranet.Teknisk_Liste" %>
<asp:Content ID="Content1" ContentPlaceHolderID="head" runat="server">
<link href="/ig_common/infragistics.reporting.css" rel="stylesheet" />
</asp:Content>
<asp:Content ID="Content2" ContentPlaceHolderID="ContentPlaceHolder1" runat="server">
<div class="Hjoerner_Blaa" >
<table cellpadding="0" cellspacing="0" style="text-align:left;" width="100%">
<tr><td class="overskrift">TEKNISK LISTE</td></tr>
<tr><td style="text-align:center"><span>UGE : <asp:DropDownList runat="server" ID="ddUger" AutoPostBack="true" OnSelectedIndexChanged="ddUger_SelectedIndexChanged">
</asp:DropDownList></span></td></tr>
<tr>
<td style="text-align:center"><div id="viewer" ></div></td>
</tr>
</table>
</div>
<script src="/scripts/Report/infragistics.loader.js"></script>
var rangeParameters = [{ Key: "Dato_Fra", Value: new Date(2013, 8, 30) },
{ Key: "Dato_Til", Value: new Date(2013, 9, 7) },
{ Key: "Uge", Value: "40" }];
$(document).ready(function () {
var _Fra = $("#Fra").text();
var _Til = $("#Til").text();
var _Uge = $("#Ugen").text();
var Fra = new Date(_Fra.substring(6),_Fra.substring(3,5) - 1,_Fra.substring(0,2));
var Til = new Date(_Til.substring(6), _Til.substring(3, 5) - 1, _Til.substring(0, 2));
rangeParameters[0].Value = Fra;
rangeParameters[1].Value = Til;
rangeParameters[2].Value = _Uge;
$.ig.loader({
cssPath: '/Styles/Report',
scriptPath: '/scripts/Report',
resources: 'igReportViewer',
ready: function () {
$(function () {
$("#viewer").igReportViewer({
renderSettings: {
definitionUri: "/Arrangement/Teknisk_Liste.igr",
serviceEndpointUri: "/ReportService1.svc/ajaxAddress/"
parameters: rangeParameters,
width: 900,
height: 650,
pageFit: 'fitToWidth'
</script>
<div style="display:none">
<asp:Label runat="server" ID="Fra" ClientIDMode="Static"></asp:Label>
<asp:Label runat="server" ID="Til" ClientIDMode="Static"></asp:Label>
<asp:Label runat="server" ID="Ugen" ClientIDMode="Static"></asp:Label>
</div>
</asp:Content>
