60
Sorting on a Templated Column?
Hi all,
I have some templated columns containing custom controls.  The infragistics default server side sort does not seem to be able to handle these correctly... attempting to sort on these columns will usually result in no change at all.  Also, if I sort on a normal, un-templated column, the cells in the template columns will sometimes not change their position according to the results of the sort.
 Any ideas on how to do this?  I've checked the help and knowledge base and found no examples!  Thanks!
