How do i split a cell in a igtbl at run time? i have a column value like #6/#9E/#9M ,when this comes in the grid it has to be splited into 3 new rows in the next column like #6
#9E
#9M
Required output
|#6/#9E/#9M--|----- #6--------||----------------|-----#9E-------||----------------|------#9M-----||----------------|----------------||----------------|----------------|
Hi Petar,
I want to split ultra grid column into 3 sub columns. And need to include sub headings to the three columns. Could you please point me towards the solution for this?
Hello Yamini,
Thank you for your reply.
Glad to hear that the issue has been resolved. Please feel free to contact me if you have any further questions regarding this matter.
THANK YOU PETAR ,IT WAS HELPFUL .
I HAVE SOLVED IT IN A SIMILAR WAY AND I GOT IT DONE.
Hello Yemini,
UltraWebGrid'sBeforeCellUpdateclientside event may be handled in this scenario in order to add 3 new rows beneath the edited one and set the corresponding cell values based on the input in the original cell. For instance:
function UltraWebGrid1_BeforeCellUpdateHandler(gridName, cellId, value){ var grid = igtbl_getGridById('UltraWebGrid1'); for (i = 0; i < 3; i++) { grid.Rows.addNew(); var row = grid.Rows.getRow(grid.Rows.length - 1); //split value based on app logic row.cells[1].setValue(value.substring(0,i + 1)); grid.Rows.remove(grid.Rows.length - 1, true); grid.Rows.insert(row, igtbl_getCellById(cellId).Row.getIndex() + 1); } }
Please note that the UltraWebGrid control is now outdated and as of .NetAdvantage 2011 Volume 2 is no longer included in our product package. I would suggest that you consider switching to the WebDataGrid/WebHieararchicalDataGrid. More information regarding these controls is available at:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/?page=Web_WebDataGrid_WebDataGrid.html
Additional samples demonstrating the features of these grids can be found at: http://samples.infragistics.com/aspnet/
Hope this helps. Do not hesitate to contact me if you have any questions.
