I would like to know if it's possible to add text annotation ( annotation need to for specific point on the chart )
Thanks again.
Thanks Stefan for the help
I applied solution that was suggested in forum thread
http://ko.infragistics.com/community/forums/t/65234.aspx
using ScaleValue and UnscaleValue methods.
Thank you for your post. I have been looking into it and I can suggest you this forum thread:
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-wpf/65234/xamdatachart-annotations
where a similar question is already discussed. Also I can suggest you see Kiril’s blog on how to combine XamTimeLine and XamDataChart in order to achieve the functionality you want:
https://ko.infragistics.com/community/blogs/b/kiril_matev/posts/using-xamtimeline-and-xamdatachart-to-build-an-annotated-view-of-your-time-series-data
Hope this helps you.
