We have created sample application using control “UltraWebListbar“
Infragistics version: 11.1.20111.2216
If we run the application in IE11 browser,
Listbar group is not clickable , not expandable and not collapsible
Then I need to change below browser settings manually as below
If I change above settings then Listbar group is clickable , expandable and collapsible ..
Also We have added below tags in WEB.CONFIG file
Please help me to work the control as we expected without changing browser settings..
Hello manikandan1984,
Please note that as of volume 11.2 the UltraWebListBar has been retired and is no longer included in the NetAdvantage for ASP.NET product toolset.
http://ko.infragistics.com/community/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx
IE11 is not supported by the classic controls, therefore in this scenario I would suggest considering upgrading to the AIKIDO component toolset:
http://ko.infragistics.com/help/supported-environments/
Feel free to contact me if you have any questions.
I have attached the screenshots showing the settings we have done in IE11 and the web.config file.
Sample code attached
