845
Marker Labels clipped by the border of the chart
I've got a line chart and the labels are being clipped by the edge of the chart:
Labels clipped
The chart is built up from data so I can't use the technique of hard coding the minimum and maximum values as suggested in this question.
I tried binding the Minimum and Maximum values to properties in the series, but despite the property values apparently being read (I set a break point and it was hit) I just got an error message displayed where the chart should be:
> XamWebChart Warning: If the AutoRange is set to false, Maximum must be greater than Minimum and Unit value must be greater than zero.
So I need to either:
1. Know how to bind the axis range correctly so I can set it to values that are large enough to see the label on the highest peak
or:
2. Increase the size of the ScenePanel so that the label on the highest peak is visible.
  • 138253
    Hello Chris,
  • 138253
    Hello Chris,
    Thank you for your post. I have been looking into it, but since I am not completely sure how your data is organized and how you bind the MaximumValue and MinimumValue Properties, I am not able to conclude what can cause your behavior, so if this is still an issue for you, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
