Does the XamDateTimeInput control and more generally the Windows UI controls work in a Windows 8.1 targeted project?
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account\My Keys and Downloads.
OK. What are the plans for the fix? Is it going to be in a service release or are we going to have to wait for 14.1?
Thank you for your feedback. The is the exact development issue that I have logged. Our development team is working on it and you will be notified when it is fixed.
Thank you for understanding.
Unfortunately this doesn't seem to help.
When using “Infragistics for Windows UI” from the Windows Extensions section of the References Manager, I get an error when opening the page containing the control.
XamlTypeInfo.g.cs
public global::Windows.UI.Xaml.Markup.IXamlType GetXamlType(string fullName)
Infragistics.Controls.Primitives.ResourceProviderWithOverrides<Infragistics.Controls.Editors.CalendarResourceId>
An exception of type 'System.ArgumentException' occurred in mscorlib.dll but was not handled in user code
When importing each reference individually, I don’t get the error, but I don’t see the control either. Where the control is defined in the xaml, there is just a blank space. This goes for the XamGrid control as well.
Thank you for your post. We have a known issue with the WinUI controls and my suggestion is to add the required assembly files for the XamDateTimePicker in order to use it :
I have logged this behavior with our developers in our tracking system, with an issue ID of 158897. I have also created a support ticket on your behalf with number CAS-128279-C6K4N6 in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
