80
Memory Leak issue with using ContentPane
I am using TabGroupPane control within XamDocManager control for adding new tabs in TabGroupPane.
I am creating ContentPane dynamically and setting its content to UserControl,
when i add ContentPane to TabGroupPane immedially Memory Usage increasing in TaskManager and after closing Pane its not releasing that memory,
every time when i add ContentPane memory increases continuously.
this is very critical issue,
please provide solution as soon as possible.
I have tried with below solution on PaneClosing event, still the same issue.
private void xamDockManager_PaneClosing(object sender, CancellablePaneEventArgs e)
            try
                if (this.xamDockManager.Panes.Contains(e.Pane))
                    this.xamDockManager.Panes.Remove(e.Pane);
                if (this.xamDockManager.DocumentContentHost.Panes.Contains(e.Pane.OwnerPane as TabGroupPane))
                    TabGroupPane tgp = e.Pane.OwnerPane as TabGroupPane;
                    tgp.Panes.Remove(e.Pane as ContentPane);
                GC.Collect();
                GC.WaitForPendingFinalizers();
                GC.Collect();
            catch { }
please help me to resolve this memory leak issue.
thanks,
uc
