I'm using NetAdvantage ASP.NET v10.3.20120.2217 - Infragistics2.WebUI.UltraWebGrid.v10.3.dll - with IE 10
If I perform a double-click on any area of a row that doesn't contain text, the even fires properly. However, if I perform a double-click on top of any text being displayed in the row, the event does not fire.
I'm surprised I haven't seen other posts about this... Is there a work-around for this issue?
Thanks..
Hi Bayta Darell
Can you please explain more in the below place of your comment?
you need to go to the properties to the UltraWebGrid and in the RowStyleDefault attribute set Wrap="True", and then apply the a class to your webgrid as shown in the link a shared before, and everything is going to work.
Also Do we have any other solutions other than setting wrap as true?
Expecting your help
Thanks!
Arun
I finally found the solution for the problem of a double click in a row on Internet Explorer 11, if the double click only works in the blank space of a cell but no in the text it's because infragistics is using a non standarized tag <nobr> you can read more about this here: https://developer.mozilla.org/en-US/docs/Web/HTML/Element/nobr.
In order to solve the problem, you need to go to the properties to the UltraWebGrid and in the RowStyleDefault attribute set Wrap="True", and then apply the a class to your webgrid as shown in the link a shared before, and everything is going to work.
Because of this kind of things, I don't like infragistics, if you have this problem you can try this solution, it's working for us.
Hello Eric, did you find the solution for this problem, I'm experiencing the same behavior in one of my applications. But i'm not using the grid to edit the cells just for show the rows, and the cell CellClickActionDefault ="RowSelect".
Hi Eric
I will be happy to assist you with your question.
One reason why you may encounter this behavior is if the CellClickActionDefault property for the UltraWebGrid is set to Edit. When this is the case, an editor takes place of the cell to enable editing of the cell's value causing the second click to never register off of the UltraWebGrid. To workaround this designed behavior, I recommend using the client-side CellClickHandler and include logic like a JavaScript timeout (link) to call a function that sets the ActiveCell to EditMode. Note, this approach allows the dblClick handler fire since the cell is not yet in edit mode. Also, the CellClickAction Default would need to be set to NotSet to ensure the editor doesn't interfere with the second click.
I have attached a sample to help demonstrate this approach. Please review the sample and let me know if you have any questions regarding this matter.
