4555
How can we send an Excel sheet as an email attachment (without saving to a file system)
 This article covers how to make an Excel Workbook that contains a worksheet, fill the WorkSheet with the contents of one Wingrid and finally Export the WorkBook as an email attachement without writing it to a disk:
 The steps are as follows:
1) We need to Instantiate a workbook object:
             WorkBook wbk = new WorkBook();
2) Set the ExportMode of the Exporter to Custom:
           UltraWebGridExcelExporter1.ExportMode = Infragistics.WebUI.UltraWebGrid.ExcelExport.ExportMode.Custom;
3)  Add a Worksheet to the Workbook:
               wbk.Worksheets.Add("Grid One");
4) Use the Export Method of the Exporter to Export the UltraGrid to the Worksheet:
                   this.UltraWebGridExcelExporter1.Export(this.UltraWebGrid1, wbk);
5) Populate an Excel object in memory; the Excel object is then persisted as an output stream:
                  MemoryStream stream = new MemoryStream();
6) Write the workbook "wbk" into our newly created stream
                    wbk.Save(stream);
  7)     Create a Byte[ to contain the stream:
                  Byte[ bytearray = (Byte[)Array.CreateInstance(typeof(byte),stream.Length);
8)   Read the stream into the Byte[:
                  stream.Read (bytearray, 0, (int)stream.Length);
9)    Create a new Stream
              MemoryStream ms = new MemoryStream(bytearray);
10)   Create an email object
               System.Net.Mail.MailMessage objMail = new System.Net.Mail.MailMessage();
              System.Net.Mail.Attachment objAtt = new System.Net.Mail.Attachment(ms, "TextFile.xls");
             objMail.From = new MailAddress("MFahim@Infragistics.com");
            objMail.To.Add(new MailAddress("MFahim@Infragistics.com"));
            objMail.Subject = "Exported Excel";
            objMail.Body = "Exported Excel";
            objMail.Attachments.Add(objAtt);
            SmtpClient c = new SmtpClient();
            c.Host = "localhost";
            c.Port = 25;
            c.UseDefaultCredentials = true;
            c.Send(objMail);
            stream.Close(); // Close the stream
Web_Excel_Stream.zip
  • 5
    One important thing to note, Before #8 make sure make sure you set the first stream to position = 0. This is clear in the attached code, but not in the text above... If you don't your attachment will be sized right, but empty.
    stream.Position = 0; // Star the stream at position 0
