I have the same problem where in the first set of loaded rows fire the rowclick event but the next set of rows loaded via XMLHttpRequest don't. I am using ultrawebgrid v5.3 and I don't see the DisplayLayOut.XMLLoadOnDemandType in my library. Is there a work around. How else to accomplish this? Thanks in advance for your response.
Thanks for this! After a good 3 weeks of searching on the net, I finally found the answer. This works now.
Hey,
Try setting the XmlLoadOnDemandType to Accumulative. The default setting of Synchronous does not work very well with full post backs. Accumulative will keep track of rows and such even after a full post back where as the default setting of Synchronous does not. It will load the first 50 rows so any click outside of that will not work.
this
.UltraWebGrid1.DisplayLayout.XmlLoadOnDemandType = Infragistics.WebUI.UltraWebGrid.XmlLoadOnDemandType.Accumulative;
Hope this helps.
XmlLoadOnDemandType
