710
WebPercentEditor format
Hello, I am migrating from 11.1 to 13.2 and when I migrated the WebPercentEdit control to WebPercentEditor, The numbers I see are different.
In the previous version I see 18.375 %
In the new version I see 1,837.500 %
here's my control code, wich is exactly the same as it was before, with the only difference of the name of the control:
<ig:WebPercentEditor ID="wpeTaxesParkingTax" MinDecimalPlaces="3" ReadOnly="true"
HideEnterKey="true" runat="server" ToolTip="<%$ Resources:ToolTips, CC_LocationPolicies_Taxes_ParkingTax %>" style="width: 100px;">
</ig:WebPercentEditor>
I set the value in the code behind, and when I debugg the assign of the value, the value is 18.375
Thank you very much!!
  • 49378
    Verified Answer
    Hello Nicole,
    The issue you are experiencing is due to the fact that by default, the WebPercentEditor has its DisplayFactor property set to 100. In this case you would want to change its value to 1. In addition to that in order to display the whole number, the MaxDecimalPlaces property would need to be set to at least 3.
