Hi.
MY Web application was reside on 2.0 Framework.I converted web site to 4.0 framework and when I ran it and try to change value in dropdown list instead of showing progress bar like it used to do in 2.0 it is blink for a second and then changed value display in dropdown list.
Actually all dropdown list which has autopostback=true behave the same except button.When I click on button progress bar is displaying the way it should be.
Thanks for your help.
P.S.Also when I am clicking on the row in WebGrid progress bar is not displaying but in 2.0 was working fine.Thanks again
Hello vaverbukh,
Please feel free to contact me if you need any further assistance with this matter.
Hello vaverbukh ,
Could you provide some additional information on the exact scenario like:
Which version of NetAdvantage are you currently using and which is its exact service release version?
On which browsers are you encountering this issue?
In general the WebAsyncRefreshPanel control has been retired in newer versions of our controls. Due to that I would recommend that you consider using the Asp.net UpdatePanel control instead since the WebAsyncRefreshPanel will not be supported under the newer browser versions.
You can find more detailed information on the supported environments here:
https://ko.infragistics.com/support/supported-environments
I’m looking forward to your reply.
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
