Is there a way to disable or enable node (in WebDataTree) checkbox base on its value?
Michael
Thanks for the reply. The post link helps.
Michael X.
Hello Mxu,
I suggest you to refer to the following forum post which has a sample that demonstrates how to disable a checkbox for the node
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/64514/disable-checkbox-if-node-is-disabled
