Trying to set visible property to false on a specific tab in a WebTab 13.2.
WebTab.Tabs(5).Visible = False
When I debug, I can see the code hitting this line but when the page renders it is visible anyway.
Question: I am doing this in Page_load. Should I be doing it somewhere else in the code instead? I need it to execute for both initial load and any postbacks.
Thanks in advance
Thanks. That works!
Hello CSpace ,
The ContentTabItem does not seem to have a Visible property in 13.2.
You can hide it by setting the Hidden property:
WebTab.Tabs(5).Hidden = True
The Page_Load event will fire on both the initial load and on postbacks so you can set the property in it.
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
