I discovered anevil(because very hard to find) bug, which cost me at least an hour of my time (just because I was lucky, and tried unlikely stuff out).
XamOrgChart tries to outsmart the coder, and evaluates all public properties, and if the type of the property is IEnumerable, it's obviously treated as ItemsSource (for the Children) (or whatever XamOrgChart does).
I created a small example demonstrating the problem:
XAML:
UserControl xmlns:ig="http://schemas.infragistics.com/xaml" x:Class
="XamOrgChartBug.MainPage"
xmlns
="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x
="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d
="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc
="http://schemas.openxmlformats.org/markup-compatibility/2006"
mc:Ignorable
="d"
d:DesignHeight="300" d:DesignWidth
="400">
<Grid x:Name="LayoutRoot" Background
="White">
<ig:XamOrgChart
InitialTreeDepth
="2"
LevelsToExpand
="1"
ItemsSource="{Binding
<ig:XamOrgChart.GlobalNodeLayouts
<ig:OrgChartNodeLayout
TargetTypeName
="Tree_Type"
Key="Children"
DisplayMemberPath
="Text"
</ig:OrgChartNodeLayout
</ig:XamOrgChart.GlobalNodeLayouts
</ig:XamOrgChart
</Grid
UserControl
Xaml.cs:
public partial class MainPage :
public
MainPage()
InitializeComponent();
var root = new Tree_Type
Parent =
null
Text =
"root"
root.Children =
Enumerable.Range(0, 3).Select(x => new Tree_Type
Parent = root,
"c"
+ x,
this.DataContext = new Tree_Type
[] { root };
public class
Tree_Type
public string Text { get; set
public IEnumerable<Tree_Type> Children { get; set
public Tree_Type Parent { get; set
> Parents
get
var p = this
.Parent;
while (p != null
yield return
p;
p =
this
When the project is started, it crashes with a meaningless error - if ran on IIS, you get "StackOverflow" exception. (probably IIS responsible...not sure - at least in my real project I got stackoverflow).
If the property "Parents" is commented in class "Tree_Type" there is no crash, and XamOrgChart is displayed.
What the heck is XamOrgChart doing with my public properties?! It should only touch those properties which I defined in the Xaml!!!
Regards
Johannes
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
https://ko.infragistics.com/my-account/keys-and-downloads/
I have logged this with development under ID: 173151 and I have also created a support ticket on your behalf: CAS-138334-S0H9Q3 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
In my example, there is a bug in the Parents-property, when this bug is fixed, the "correct error" (StackOverflow) is displayed, the corrected code for the Parents-property:
> ParentsXXXXXXX
p = p.Parent;
