475
UltraGrid Snapshot on any event
I want to snapshot of Ultra Grid (selected columns) on any event basis. Please give me any idea for this.
  • 48586
    I am just checking about the progress of this issue. Let me know If you need my further assistance on this  issue?
    Thank you for using Infragistics Components
  • 48586
    Verified Answer
    You could get snapshot of the selected grid columns only if they are fully paint. So what I could suggest you is to put your grid in a panel and to resize the grid so that all its content to match the grid size. Then you will be able to draw the grid to a bitmap with DrawToBitmap(…) method and from this bitmap you could copy only the areas of the selected columns. I’ve implemented this approach in a simple sample, please see the attached zip. I should note that drawing of whole content of the grid may leads to a performance issue, depends of the count of the records, filters, summaries and etc.
    I hope that this will helps you.
    139037.zip
