Would like to hide the header portion of the Dialog box so it displays like a Window with WindowStyle="None" set.
Can't find anyway to make this happen.
Thanks for the help...
Thanks again.
It works a treat, thanks...
Sincerely,
Krasimir, MCPD
Developer Support Supervisor - XAML
www.infragistics.com/support
Thank you for your reply. I have modified the sample to show how you can remove the borders on the XamDialogWindow in the loaded event. Also, if you wish to customize the XamDialogWindow’s appearance, you can re-tempalte it and change it appearance in xaml. You can locate the default style for the control here:
C:\Program Files (x86)\Infragistics\2014.1\WPF\DefaultStyles\DialogWindow\ generic.xaml
Please let me know if you need any further assistance on the matter.
Seems to work, except that I would like to get rid of the border as well? Top, bottom and sides.
