Is it possible to bind a dynamic object to the WinUI Html grid? If so can you modify the Bind to JSON example.
Something like this in javascript?
var parsedValue = JsonValue.Parse({\"name\":\"Willem\"}");
var parsedObject = parsedValue.GetObject();
var firstName = parsedObject["name"].GetSting();
Rich
Hello rich0809,
I’m just following up to see if you’ve been able to resolve your issue. If you have any questions or concerns or if you need further assistance please let me know.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
Hello Rich,
If you mean as a data source you would need to make sure that the data is parsed into one of the supported data types for the grid.
Local:
◦JSON
◦XML
◦JavaScript Object Arrays
◦Strings of XML or JSON
◦JavaScript functions returning data in any of the formats above
◦Existing HTML structures (such as a HTML table filled with data)
Remote:
◦REST GET
◦WCF REST (JSON & XML)
◦JSONP Service
◦Any REST Service
For more details you can refer to the following article:
http://help.infragistics.com/doc/jQuery/2014.1/CLR4.0/?page=igGrid_igDataSource_Architecture_Overview.html
If you need to bind some other option of the grid you could do so by defining a new namespace with the properties and settings you want and then applying it to the grid via the namespace.
For example:
<code>
var data = [{ "OrderID": 10285, "ProductID": 1, "UnitPrice": "14.4000", "Quantity": 45, "Discount": 0.2 }, { "OrderID": 10294, "ProductID": 1, "UnitPrice": "14.4000", "Quantity": 18, "Discount": 0 }];
WinJS.Namespace.define("Sample.Data", {
data: data,
heightInPx: "50px"
</code>
And then use them in the grid:
<table id="Table1" data-win-control="Infragistics.UI.Grid"
data-win-options='{
autoGenerateColumns: false,
columns: [{headerText:"OrderID", key:"OrderID"},{headerText:"UnitPrice",key:"UnitPrice"},
{headerText:"Quantity",key:"Quantity"} ,{headerText:"Discount",key:"Discount"}
dataSource: Sample.Data.data,
dataSourceType: "json",
width: "100%",
height: Sample.Data.heightInPx,
Let me know if you have any questions or concerns regarding this.
Developer Support Engineer II
