285
Dynamically changing HeaderText of a Text Column in XamGrid
I need yet another help!!
I am dealing with Hierachial XamGrid in which I want to bind header text of a TextColumn in xamGrid to a variable in ViewModel (I am using MVVM architecture).
That is if I select 'April' in a combo box(combo bos is not a part of the grid) then Header Text of textColumn in XamGrid should be 'Net Movement for April'; If I select 'September' in the combo box then the Header Text should change to 'Net movement for September'.
How to do this in Silverlight Infragistics.
Thanks!!
