55
Node.DataItem Is Nothing
I have created a dataset with tables and associated relations to populate an UltraWebTree.
 Binding works using the following code, and the tree displays correctly:
 Me.uwtPendingDocuments.DataSource = PendingDocuments.Tables("Queues").DefaultView
Me.uwtPendingDocuments.Levels(0).RelationName = "FK_Queues_References"
Me.uwtPendingDocuments.Levels(0).ColumnName = "Name"
Me.uwtPendingDocuments.Levels(0).LevelKeyField = "ID"
Me.uwtPendingDocuments.Levels(1).RelationName = "FK_References_Documents"
Me.uwtPendingDocuments.Levels(1).ColumnName = "Reference"
Me.uwtPendingDocuments.Levels(1).LevelKeyField = "ID"
Me.uwtPendingDocuments.Levels(2).RelationName = "FK_Documents_Attachments"
Me.uwtPendingDocuments.Levels(2).ColumnName = "FileName"
Me.uwtPendingDocuments.Levels(2).LevelKeyField = "ID"
Me.uwtPendingDocuments.Levels(3).ColumnName = "FileName"
Me.uwtPendingDocuments.Levels(3).LevelKeyField = "ID"
Me.uwtPendingDocuments.DataMember = "Documents"
Me.uwtPendingDocuments.DataBind()
However, when the NodeBound event fires, e.Node.DataItem is nothing, and I need to access the information in the DataItem to modify the nodes.
Am I doing something wrong on the databind?
Any help will be appreciated
  • 28464
    By the way, you can always check out the new WebHierarchicalDataSource control we just released, it makes databinding UltraWebTree (and Menu, Grid, etc) to hieararchical structures so much easier - it practically can be done with a few mouse clicks in the designer.
    You can check out the WHDS samples online here:
    http://samples.infragistics.com/2008.2/webfeaturebrowser/default.htm
  • 7694
    Please, take a look at the attached picture for information on how I bind UltraWebGrid to DataSet, members of e.Node.DataItem and values. It is working fine in my case.
    What am I missing? Can you use something similar in your project?
    BindTreeToDataset.rar
