435
Timecode Mask
Hi Infragistics,
We have a need for an editable video timecode field in an application. We'd like to xamMaskedInput (v2014) but have hit a problem with some (optional) special characters.
The basic timecode is this...
HH:MM:SS:FF
Where...
HH = 00 - 99
MM = 00 - 59
SS = 00 - 59
FF = 00 - 24
And this mask works ok (with a PromptChar of "")...
{number:0-99}:{number:0-59}:{number:0-59}:{number:0-24}
But we would like some optional characters at the beginning and end, which the user will enter in certain situations. At the beginning we would like either a "+" or "-" and at the end a "*"
So...
[+ or -]HH:MM:SS:FF[*]
I've managed to add the "*" with the following mask at the end...
{char:1:*}
But I've tried to get "+" and "-" working and just can't seem to find a way using the standard masks...
http://ko.infragistics.com/help/wpf/xaminputs_masks.html
The "-" and "+" masks already defined, don’t work for this situation.
Is it also possible to have the ":" literals in the above example only appear when the cursor has reached the correct position?
Using a PromptChar of "" the initial edit text looks like this...
Which is not ideal. We've tried using a PromptChar of "0" but then the "*" mask looks odd.
It sounds like this is too custom for xamMaskedInput  and maybe we need a masked control using Regex support?
Any help would be much appreciated.
