Hi Infragistics Team
The event in Client side 'CellClickHandler' is not being fired in Chrome.I'm using UltraWebGrid :Infragistics35.WebUI.UltraWebGrid.v11.1, Version=11.1.20111.1006
I need a suggestion ,as it is an important issue .My Client is demanding a solution for this as they mainly use Chrome as their default browser.
Is there any way so that we can cahnge our code , not from clientside but from server side.
Can u give me any sample code for this (to work from server side only) for UserAgent as Chrome ,so that i can overcome this problem.
Please check the Function 'uwgSubstitutes_CellClickHandler(gridName, cellId, button)' in the uwgworksheet.aspx.txt page. Please suggest me solution .
Thanks inAdvance
I am following up to see if the information provided has resolved this matter.
Please let me know if I may be of further assistance with this matter.
I see that you are using the UltraWebGrid. I would like to note that the UltraWebGrid does not support chrome. As the UltraWebGrid was retired after v11.1 if you want to support Chrome and later version of browsers I recommend you upgrade to either the Infragistics ASP.NET Ajax controls like the WebDataGrid or the Infragistics IgniteUI for jQuery.
http://ko.infragistics.com/community/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx
http://ko.infragistics.com/samples/aspnet/
http://igniteui.com/
As you can see in our supported environments page support for Chrome was not implemented until v11.2 and later. http://ko.infragistics.com/support/supported-environments
