Having a few issues with the WebEditors in Infragistics 12.1 and IE 11. I have already replaced all instances of WebNumericEditor but now find that the WebDateTimeEditor also does not seem to work with IE 11. All is fine with Chrome but with IE you cannot type in a time as the data is entered backwards so if for example you type 11:00 it appears as 00:11.
Hello Chris,
Have you been able to resolve the issue?If you have any concerns or questions, please feel free to contact me.
actually version 12.2 of Infragistics ASP.NET components is not supported under IE 11, please have a look at this link:
http://ko.infragistics.com/support/supported-environments
So I suggest you to upgrade your Infragistics package to a newer version.
If you have additional questions, please don't hesitate to ask.
Perhaps it is a .NET dependancy thing - try the attached project. None of the controls work for me under IE 11
I tested the WebDateTimeEditor in v v.12.1 with IE 11 and the time format is working properly at my side.
Can you please review the sample and let me know if you can reproduce the behavior you are describing? You can also send me your project, so that
I will be able to investigate the issue. Looking forward to your answer.
