I have a webpage which original use the UltraWebGrid v9. After we upgraded to V11.1, the selectRow function does not work in IE8 and IE9, but it works in IE11. Does anyone have the similar situation? Do have any solution to solve it?
Thanks.
Following is the Asp.Net code
<%@ Register Assembly="Infragistics2.WebUI.UltraWebGrid.v11.1, Version=11.1.20111.1006, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebGrid" TagPrefix="igtbl" %>
<RowSelectorStyleDefault BackColor="#A5CFFF" BackgroundImage="url('\Images\rowselector.gif')" CustomRules="background-repeat: no-repeat; background-position: right;"> <BorderDetails ColorBottom="#D6D3D6" ColorTop="#D6D3D6" StyleBottom="Solid" StyleTop="Solid" WidthBottom="1pt" WidthTop="1pt" /> </RowSelectorStyleDefault>
<SelectedRowStyleDefault BackColor="PaleTurquoise"></SelectedRowStyleDefault> <RowStyleDefault Font-Names="Arial Unicode MS" Font-Bold="False" Font-Size="8pt" HorizontalAlign="Left" CustomRules="background-repeat: no-repeat; background-position: 0;"> <BorderDetails ColorBottom="#D6D3D6" ColorTop="#D6D3D6" StyleBottom="Solid" StyleTop="Solid" WidthBottom="1pt" WidthTop="1pt" /> <Padding Left="5px" Right="5px"></Padding> </RowStyleDefault>
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hello Rocky,
Could you let me know the result after you tested with the latest SR as Alan has suggested ? If you still experience this issue please feel free to send your sample for investigation.
Rocky,
Have you tested with the latest service release of 2011 Volume 1? I There were a few bug fixes related to selection so maybe the behavior will be corrected if you apply the service release.
If that doesn't resolve the issue, if you provide a sample that reproduces the behavior that you see, I could step through it and see if there is a possible workaround.
Let me know if you have any questions
