135
Image from DataSource doesn't load
I'm using Infragistics 14.2 in an ASP.NET Web Forms project (4.5). I copied over a report from a 14.1 project and updated all the data bindings. However, the report fails to load an image from the database.
I tested to see if it pulled the correct image record (it does, I can have a label display the image Id, etc.), but instead of displaying the image (from binary data) it shows a URL like: https://localhost:12345/477c4e45-3670-4d2d-be03-e2bf27fcffeb/image.1.False.igrResource
The resource guid in the URL changes every time, but the end of the URL (image.1.False.igrResource) is always the same.
In my Web.config, I noticed some changes between 14.1 and 14.2. My current 14.2 project has a different handler name (14.1 used "IgReportingResourcesHandler" and had an additional parameter: resourceType="Unspecified"). Everything else works fine, though, so I don't know what the issue is.
<handlers>
      <add name="ReportResourceHandler" path="*.igrResource" verb="*" type="Infragistics.Reports.Server.ResourcesHandler, InfragisticsWPF4.Reports.Server.v14.2, Version=14.2.20142.1016, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
    </handlers>
