355
XamReportPreview Performance issue for preview generation
Hi Support,
      We are currently using XamReportPreview control (WPF 14.2) version to preview the grid data. At a given time in the xamdatagrid we have approximately 5000 records with minimum 50 columns(the columns are dynamic); previewing  these many records using XamReportPreview control takes quite a bit of time to generate the preview. We even tried previewing 1000 records using this control, however it took around 34 second to generate preview for 1000 records. Also we found some related post for the same but not found any specific workaround. Can you please let us know if there is any way to reduce the time to generate the preview for bulk data.
Also we are trying to convert .xls into .xps to show preview using "DocumentViewer" control of WPF. So can you please let us know if Infragitiscs has any other control or method to convert the excel file to the “XPS” document format?
--Related threads
http://ko.infragistics.com/community/forums/t/73053.aspx
http://ko.infragistics.com/community/forums/t/73499.aspx
http://ko.infragistics.com/community/forums/t/66682.aspx
Thank you
