330
WebAsyncRefresh Panel - LiteralControl
I have a problem using below line. I have a web async panel in my page. I want to open one page which was DownloadFile.aspx for that I used below code. In my system It was working fine. But when I installed my project into Production environment it was not working. In DownloadFile.aspx page load event have Response.Write() and Response.clear() these statements.  Whether can I use Response object in web async panel or not? Can you give me brief idea?  wrpWorkSheet.Controls.Add(new LiteralControl("<script language='javascript'>window.open('DownloadFile.aspx', '', '');</script>")); In DownloadFile.aspx – Page load event Response.Clear();            Response.Buffer = true;            Response.ContentType = "application/pdf";            string file = GetStoreValue(Constants.PreviewFileName).ToString();            string displayFileName = GetStoreValue(Constants.PreviewDisplayFileName).ToString();            SetStoreValue(Constants.PreviewFileName, null);            SetStoreValue(Constants.PreviewDisplayFileName, null);            FileStream LimitedPowerofAttorneyforUSBankStream = new FileStream(file, FileMode.Open, FileAccess.Read);            byte[ LimitedPowerofAttorneyforUSBankBuffer = new byte[LimitedPowerofAttorneyforUSBankStream.Length];            LimitedPowerofAttorneyforUSBankStream.Read(LimitedPowerofAttorneyforUSBankBuffer, 0, (int)LimitedPowerofAttorneyforUSBankStream.Length - 1);            Response.AddHeader("content-disposition", "attachment;filename=" + displayFileName);            Response.BinaryWrite(LimitedPowerofAttorneyforUSBankBuffer);            LimitedPowerofAttorneyforUSBankStream.Close();            File.Delete(file);            Response.End();            Response.Flush();
            Response.Close();
  • 475
     Hi Sudheer
       I have a very similar problem. I have create a page with a warp from this i trigger a link to a new windows that dowmloads a file using the exportexcel or Response.BinaryWrite.
       Everything work really nice in my local computer using IE7 and visual studio. When I deploy the application to the server it only work fine with IE6 but not with IE7 .IE7 closes the new window without showing any error message.
      Is infragistic not compatible with IE7 for exporting grids to excel and pdf????? Have you some answer
     Have you found a reason for that???? Please help.. I need that as soon as possible. Thanks Sudheer. Below my code:
            if (contentReportDs != null)
                uwgExportReport.DataSource = contentReportDs;
                switch (Convert.ToInt32(Enum.Parse(outputFormatReceived, outputFormat)))
                    case 0: // CSV file
                        if (this.loadPlugin(outputFormat, ref aMessage))
                            Panel csvPanel = ((Panel)this.plugin.generate(this.wpDownloadReport, contentReportDs));
                            Label csvLabel = new Label();
                            for(int i=0; i<csvPanel.Controls.Count;i++)
                                if (csvPanel.Controls[i] is Label)
                                    csvLabel = csvPanel.Controls[i] as Label;
                            string csvContentToShow = csvLabel.Text;
                            csvContentToShow = csvContentToShow.Replace("<br />", "" + '\n');
                            byte[ bytFile = System.Text.Encoding.UTF8.GetBytes(csvContentToShow);
                            Response.Clear();
                            Response.ContentType = "application/vnd.ms-excel";
                            Response.AddHeader("content-disposition", "attachment;filename=" + fileName);
                            Response.Charset = "";
                            Response.Cache.SetCacheability(HttpCacheability.NoCache);
                            // If you write,
                            // Response.Write(bytFile1);
                            // then you will get only 13 byte in bytFile.
                            Response.BinaryWrite(bytFile);
                            Response.End();
                        break;
                    case 2: // XLS
                        uwgExportReport.DataBind();
                        uwgReportExpXls.ExcelStartRow = reportParamValueList.Count + 6;
                        this.uwgReportExpXls.DownloadName = fileName + ".XLS";
                        this.uwgReportExpXls.Export(uwgExportReport);
                        break;
                    case 3://CSV
                            for (int i = 0; i < csvPanel.Controls.Count; i++)
                            csvContentToShow = csvContentToShow.Replace("&lt;", "" + '<');
                            csvContentToShow = csvContentToShow.Replace("&gt;", "" + '>');
                            Response.Clear();
                            Response.ContentType = "text/xml";
                            Response.AddHeader("content-disposition", "attachment;filename=" + fileName + ".xml");
                            Response.End();
                        break;
                    case 4://PDF
                        this.uwgReportExpDocument.Format = Infragistics.Documents.Report.FileFormat.PDF;
                        this.uwgReportExpDocument.DownloadName = fileName + ".pdf";
                        // trigger export
                        this.uwgReportExpDocument.Export(uwgExportReport);
                        break;
                    case 5://XPS
                        this.uwgReportExpDocument.Format = Infragistics.Documents.Report.FileFormat.XPS;
                        this.uwgReportExpDocument.DownloadName = fileName + ".xps";
                        // trigger export
                        break;
                    case 6://NOtepad -- Text
                        this.uwgReportExpDocument.Format = Infragistics.Documents.Report.FileFormat.PlainText;
                        this.uwgReportExpDocument.DownloadName = fileName + ".txt";
                        // trigger export
                        break;
                    default:
                        //this.wpDownloadReport.Controls.Clear();
                        if (this.loadPlugin(outputFormat.Replace('_',' '), ref aMessage))
                           this.wpDownloadReport.Controls.Add(this.plugin.generate(this.wpDownloadReport, contentReportDs));
                            this.wpDownloadReport.Visible = true;
                        else
                            this.tbAlertMessage.Text = aMessage;
                        break;
