I am using Infragistics 11.1 version ultraweb grid. In IE 11.0.9600.17633 version fixed header is not working. When we scroll the vertical scroll bar header also moving.
Please help me to resolve this issue asap.
Narmatha.P
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hello Narmatha,
The UltraWebGrid has not been designed for IE11 and has never been tested with it. As stated in the Supported Environments page IE11 is supported by .NetAdvantage 13.1 or higher. Using older products in IE11 is expected to cause issues.
I suggest that you upgrade your application to 13.1 or higher in order to support IE11.
Please let me know if you have further questions on the matter.
