120
Grouping a XamGrid with ItemSource bound to a VirtualCollection
I am using a sample I found from your documentation to make use of virtalCollection. I have filtering and sorting working but grouping has proven a bit difficult.
http://help.infragistics.com/Help/Doc/Silverlight/2012.1/CLR4.0/html/Virtual_Collection_Using_Grouping.html
in my ItemDataRequested event handler
I have a block that looks like ....
ObservableCollection<GroupDescription> groupDescriptions =
(sender as VirtualCollection<MyData>).GroupDescriptions;
// cycle through the group descriptions
foreach (GroupDescription gd in groupDescriptions)
When grouping on the UI the event fires but there is nothing in the GroupDescriptions. Also the CanGroup flag of the VC is false.
Any insight or a pointer to a sample would much be appreciated.
  • 6759
    I have logged this behavior in our tracking system with ID 200733 and the following case was created for you: CAS-156542-K3S8S3. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
    Sincerely,
    Konstantin
    Software Developer
    Infragistics, Inc.
    www.infragistics.com/support
