85
Viewing different columns in same Band
Hi! I have this scheme of Data on my Ultrawebgrid. By default all columns that have information are visible, now, I need to hide some columns depending of the value at TasCodigo in the 2nd Band. For example, if the value is "1" I need to hide since "AfoCodigo" column until "AfoIncorporationDate", and if the value is "2" I need to hide since "AcoCodigo" until "AcoStatus". Is it this posible ?
<Bands>
                        <igtbl:UltraGridBand>
                            <AddNewRow View="NotSet" Visible="NotSet">
                            </AddNewRow>
                            <Columns>
                                <igtbl:UltraGridColumn BaseColumnName="TasCodigo" Key="TasCodigo">
                                </igtbl:UltraGridColumn>
                                <igtbl:UltraGridColumn BaseColumnName="TasDescripcion" Key="TasDescripcion">
                                    <Header Caption="TXT_DESCRIPCION">
                                        <RowLayoutColumnInfo OriginX="1" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                            </Columns>
                        </igtbl:UltraGridBand>
                            </AddNewRow>
                            <Columns>
                                <igtbl:UltraGridColumn BaseColumnName="AssCodigo" DataType="System.Int32" Hidden="True"
                                    Key="AssCodigo">
                                <igtbl:UltraGridColumn BaseColumnName="TasCodigo" DataType="System.Int32" Hidden="True"
                                    Key="TasCodigo">
                                    <Header>
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AcoCodigo" DataType="System.Int32" Hidden="True"
                                    Key="AcoCodigo">
                                    <Header>
                                        <RowLayoutColumnInfo OriginX="2" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AcoCompanyName" Key="AcoCompanyName">
                                    <Header Caption="DP_COMPANYNAME">
                                        <RowLayoutColumnInfo OriginX="3" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AcoJurisdition" Key="AcoJurisdition">
                                    <Header Caption="DP_JURISDICTION">
                                        <RowLayoutColumnInfo OriginX="4" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AcoId" Key="AcoId">
                                    <Header Caption="DP_ID">
                                        <RowLayoutColumnInfo OriginX="5" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AcoDateIncorporation" DataType="System.DateTime"
                                    Format="MM/dd/yyyy" Key="AcoDateIncorporation">
                                    <Header Caption="DP_DATEINCORPORATION">
                                        <RowLayoutColumnInfo OriginX="6" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AcoStatus" Key="AcoStatus">
                                    <Header Caption="DP_STATUS">
                                        <RowLayoutColumnInfo OriginX="7" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AfoCodigo" DataType="System.Int32" Hidden="True"
                                    Key="AfoCodigo">
                                    <Header>
                                        <RowLayoutColumnInfo OriginX="8" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AfoFoundationName" Key="AfoFoundationName">
                                    <Header Caption="DP_FOUNDATIONNAME">
                                        <RowLayoutColumnInfo OriginX="9" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AfoJurisdition" Key="AfoJurisdition">
                                        <RowLayoutColumnInfo OriginX="10" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AfoIdNumber" Key="AfoIdNumber">
                                    <Header Caption="DP_IDNUMBER">
                                        <RowLayoutColumnInfo OriginX="11" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AfoStatus" Key="AfoStatus">
                                        <RowLayoutColumnInfo OriginX="12" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="AfoIncorporationDate" DataType="System.DateTime"
                                    Format="MM/dd/yyyy" Key="AfoIncorporationDate">
                                        <RowLayoutColumnInfo OriginX="13" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                            </Columns>
                    </Bands>
</Code>
