155
WebDateTimeEdit embedded in UltraWebGrid shows wrong format in edit mode
Using version 6.2
I have a problem with a wizard server control that has an ultrawebgrid on the second page that embeds a webdatetimeedit control. When the user views the first page the ultrawebgrid has not been rendered so the webdatetimedit control is visible at the bottom of the page. If I declaritively set the webdatetimeedit control visible=false the date is displayed in long date/time format in edit mode even though I specify short date format when I do get to the second page. I do not want to set up the ultrawebgrid column definitions until I get to the second page because of some overhead issues.
Here some simplified HTML and code that demonstrates the problem without the wizard.
<body>
    <form id="form1" runat="server">
<div>
<igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server"/>
        </div>
<igtxt:WebDateTimeEdit ID="WebDateTimeEdit1" runat="server" DataMode="EditModeText" Visible="false"/>
</form>
body>
And the code behind...
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
With UltraWebGrid1.Columns
If .Count = 0 Then
.Add("Date", "Date")
            .FromKey(
"Date").DataType = GetType(Date).ToString
            .FromKey(
"Date").DefaultValue = Now()
            .FromKey(
"Date").EditorControlID = WebDateTimeEdit1.UniqueID
            .FromKey(
"Date").Type = ColumnType.Custom
            .FromKey(
"Date").Format = "MM/dd/yyyy"
End If
End With
    With UltraWebGrid1.Rows
        .Clear()
        .Add()
Dim oRow As UltraGridRow = UltraWebGrid1.Rows(0)
        oRow.Cells(0).Value = Now()
        oRow =
Nothing
End With
    UltraWebGrid1.DisplayLayout.AllowUpdateDefault = AllowUpdate.Yes
    UltraWebGrid1.DisplayLayout.CellClickActionDefault = CellClickAction.RowSelect
End Sub
If you double-click the cell you will see the date format changes from short date to long date/time when the cell is put in edit mode. Removing the visible="false" attribute from the webdatetimeedit control corrects this behaviour but leaves the webdatetimeedit control visible until the .EditorControlID attribute on the ultrawebgrid is rendered.
Any observations would be welcome.
Terry Hutt
  • 5
    Hi iam having the following problem
    We set EditModeFormat  of WebDateTimeEdit to "hh:mm:ss tt" but the last AM and PM in spanish culture(es-CO) is truncating for ex "10:10:10 a." instead of "10:10:10 a.m.", this is working fine for en-US like 10:10:10 AM.Let me know what iam doing wrong.
    MuthuKumaraSamy,
