325
UltraTab Control
Hi ,
We are using RFT 8.0 (VB.Net 2005 Framework)
We have a requirement to work on UltraTab Control which our application uses as Sticky Notes on Desktop
Following are the my requirements
 Find the Tab Highlightened
 Find the Tab Text
 Double click on The Tab
 Find the Notes under the Tab
 Delete a Tab
Could anyone please provide the code snippet for the above req.
Attached is the sample document for more Info
Thanks in Advance
  • 6729
    Suggested Answer
    Sorry for the late replay but somehow this thread got buried in my inbox. Below is some code snippet for the action you described
    MsgBox(UltraTabControl1TabbedPage().GetNAProperty("SelectedTab.Text").ToString())
     Find the Tab Text
    MsgBox(UltraTabControl1TabbedPage().GetNAProperty("Tabs[0].Text").ToString())
    UltraTabControl1TabbedPage().DoubleClick(AtText("tab2")) ' By its Text
    UltraTabControl1TabbedPage().DoubleClick(AtPosition(2)) ' By its Index
    This will depend on the type of control you have for the notes and the structure of it inside each tab, for example if your notes are actually UltraTextEditors and placed directly under inside the tab then you can do something like this to get the text of the text editor:
    Dim FoundTestObject() As TestObject = UltraTabControl1TabbedPage().Find(AtDescendant(".class", "Infragistics.Win.UltraWinEditors.UltraTextEditor", "Name", "ultraTextEditor1"))
    Dim TextEditor As Infragistics.RFT.NetTestObjects.UltraTextEditorTestObject = FoundTestObject(0)
    MsgBox(TextEditor.GetText())
     Delete a Tab
    The TabControl does not support deleting a tab via its UI, so if your application has some custom way to do this (like Right Click the tab and select Delete from a context menu) you could do something like:
    UltraTabControl1TabbedPage().Click(RIGHT, AtPosition(0))
    ' Selct Delete from the context menu ...
    I hope this was helpful
