Hi Ammar,
I have written one RFT script in admin login and when im tring to run it on another login with admin rights
it is failed to run... it is unable to identify the objects in the application but it is identifying the login page.
i'm unable to understand why it is not identifying..
thanks in advance,
Rekha
Hi Rekha,
I think the best way to assist you in this issue would be to contact our Developer support department. they should be able to work with you on setting up a debug session so we can take a look at your configuration using remote desktop. You can submit your support request here: http://ko.infragistics.com/support/submitrequest.aspx
Ammar
While i installed Testadvantage in admin login i selected everyone,
Now i installed RFT, Testadvantage again, but the issue is not resolved, and one more thing i'm facing
the same problem with testadvantage sample application also.
thanks in advance.
Rekha.
Can you try Installing TestAdvantage when you are logged on as the new user. What type of installer you'll see (i.e: new install vs repair)
hi Ammar,
Customization folder includes infragistcs.RFT... dll assemblies and infragistics.rftcust file,
I'm not getting any error message, but the script is coming out without executing.
Please verify the following:
- Customization Folder include Infragistics.RFT.....dll assemblies
- Customization Folder include Infragistics.rftcust file
What is the error message you are getting when replaying the script?
