I am using IBM Rational Functional Tester 8.2 and am having issues when play back the script. The object is there, but RFT just can't see it. Recording seems fine.
Play back worked with RFT version of 8.1.
Here's the error message;
Any ideas?
Thanks.
When you have an object called html_headerbot (), that is the actual Flex object that was captured or just HTML that surrounds the flex canvas, button. . . what do you have? C9020-662 VCE
Also what version of flex and rft are you using?
The Eur project was compiled with the right flexible libraries ???
I have many questions, maybe more than you, however, give me some answers and I can give you a theory.
I didn't see the screenshot! can you re-attach.
Is this an UltraCombo or UltraComboEditor control? what is the test object name in the object repository?
can you help me Veifying the dropdown option being present or not ..Just in screen shot how do in verify whether Service Fee option available or not by RFT automating it
Tina,
Because TestAdvantage has no specific code that refers to the Operating System and this issue is occuring on Windows 7 and not on Windows XP it would appear that this is an IBM issue. I would advise you to reach out to IBM to have them research this further.
Jenny,
Could you attach the sample app that has the UltraCombo to this forum thread so that I could look into this?
