When i try to record swfcheckbox, it records and the script is:
Window("Book1").SwfWindow("Workspace Window").SwfCheckBox("SwfCheckBox").Set "OFF"
I have same problem, I ran all 4 Script, out of 4, 3 passed but I got Run time error for ScriptWinSchedule Appointments at line 87, that [AppointmentEdit]: Specified appointment not found. My Question is I have to again install TA or any patch to download.
First check with "ON", "OFF" methods, if both are getting same error than
Your TeastAdvange was not configured properly.
Run the sample infragistics automation test scripts located at
\Program Files\Infragistics\TestAdvantage for Windows Forms XXX\Samples\Scripts
if these scripts are executed fine your TA configuration is right otherwise you need to configure TA again with QTP.
Sridhar
