I submitted this as a support request with HP and with Infragistics but I thought perhaps the infragistics community may be familiar with this issue as well since I'm having a devil of a time resolving this problem.
I have QTP 9.5 installed with TestAdvandage 2006 Vol 3 CLR 1.X
I was told to make QTP 9.5 to function with TestAdvantage there were some registry tweaks I needed to make. I completed those and what is happening now is that every time I try to record OR learn objects into the Object Repository QTP crashes with the following error:
Error message:Runtime Error!Program: C:\Program Files\HP\QuickTest Professional\bin\QTPro.exe
R6025-pure virtual function call
The application under test is a Windows App and to reproduce this here's what I do:
Launch QTPLaunch Application Under TestSelect New (to add a new record in application under test)Open OR in QTP.Select "Add Object to Repository" button.Click on "FirstName" field in Application under test.Observe QTP freezes and proceeds to crash.
1. Check first your C: drive available space. you don't have proper space in C: it won't work. (Minimum 1GB Free Space is Required)
2. Are you Learning the OR with "All Object Types" then Stop this add individually.
3. Check for QTP Installation.
4.Check for Test Advanatge properly configured with QTP or Not.
Try & Check With this...
Sridhar
