I have a dropdown object in the SwfTable. When I activated on the cell, dropdown object is present. I want get data in dropdown but cannot. Please help me.
Thanks.
Did that work for you?
If you want to get the items in the ValueList for a particular cell try something like this:
Sub GetValueListData()
Dim ItemCount ItemCount = SwfWindow("Company").SwfTable("Grid").GetNaProperty("DisplayLayout.Bands[1].Columns[4].ValueList.Rows.Count")
MyData = ""
For i = 0 to ItemCount -1 step 1MyData = MyData & SwfWindow("Company").SwfTable("Grid").GetNaProperty("DisplayLayout.Bands[1].Columns[4].ValueList.Rows[" & i & "].Cells[1].Text") & vbCrLfNext
MsgBox MyDataEnd Sub
GetValueListData()
If you just want to get the value from a cell in a child row you can do something like this:
MyData = MyData & vbCrLf & SwfWindow("Company").SwfTable("Grid").GetCellData("0;1","Color")
Let me know if that works for you.
I am using this and this works
Sub GetCellData_Example1() 'The following example uses the GetCellData method with Infragistics UltraWinGrid control to return the data 'contained in the second row of the "Description" column within the second band level.
MyData =SwfWindow("EMT").SwfWindow("EMTReinsurance").SwfTable("ugAviLayers").GetCellData("0;0","PolicyRef")MsgBox MyDataEnd SubCall GetCellData_Example1()
But i want to get the cell data at run time by using getrow count and column count but i have two bands.
how can i make that work ????
Dennis,
Your approach should work fine.
Let me know if you have any questions with this matter.
Alan
