Version .... CLR 2 2006 vol2
I can access cell data in the table as in the following code but I'm not sure how to access grab the column names.
For i = 1 To CountColumns Col = SwfWindow("CaridianBCT Service Maintenanc").SwfTable("machineHistoryGrid").GetCellData(3, i)
Richard
Hello Ravi,
If you still have any concerns or questions I will be glad to help. If you need any additional assistance don’t hesitate to ask.
REgards
Ravi Salunkhe said:I had installed the add-in with selecting as "free version", is this valid?
If I understand well your scenario, than the answer is: No. I suppose that your application using non version free assemblies. So you should choose the appropriate version (12. 1 CLR 2.0 or 12.1 CLR 4.0) depending of assemblies that you are using into your AUT. Please use the Version Utility tool to choose the right version and CLR
Regards
Hey Georgi,
I had installed the add-in with selecting as "free version", is this valid? as i'm unable to get the recorded script properly and it still takes the x,y co-ordinates.
while setting the filter and stuff.
Ravi Salunkhe
You could download the trial version of TestAdvantage 12.1 from the link http://ko.infragistics.com/products/downloads/archived . By this way you could test your application .
oops!...i just missed out.....actually the TestAdvantage setup i have is of 2012.2!...and thanks for the vid...will chk the code though!
Lemme get back to you on this...
