330
Grid Table Function SetCellData Locks both QTP and Application Under Test
Here is my code:
GridDataTableObject.ActivateCell iRow, "CheckedColumn"
GridDataTableObject.SetCellData iRow, "CheckedColumn", "TRUE"
If I put this at the last line of my script, so that QTP exits after this, it will check the checkbox in the column cell fine.
However if I add any other code after this, or if this is part of a QTP RunAction command where I am performing multiple iterations of this script, so that muliple items are being selected and checked back to back, it will lock both the AUT and QTP.  I can launch Windows Task Manager, and end the AUT process, then QTP will release.
High logging in QTP captures nothing.
