180
UltraWinGrid - selecting a check box in a column
I am facing a problem in trying to select a checkbox in an ultraWinGrid control (screenshot attached)
The checkbox lies within one of the cells and I am not able to set the checkbox to an On state.
Is there a native method/property which can be used to set the checkbox to a "checked" state?
SwfWindow("xxx").SwfWindow("yyy").SwfTable("zzz").Object.SomeMethod
I'm using QTP 10, Test Advantage 2005 Volume 3 CLR 1.0. Application is coded in c#.
Any help would be appreciated.
Chandan
