65
Can't get SwfTable details
I'm using QTP 10 (fresh installation, with .NET add-in installed and loaded) with TestAdvantage 9.2CLR2.0 (licensed version).
I was trying to get the cell data from an SwfTable object but kept failing.
From a product quote console (see screen image),  the middle part (with headers like Time, Contact, Product, etc.) is an SwfTable object, as recognized by the object spy.   But I wasn't able to retrieve the data from the cells.
I tested with the following scripts:
If SwfWindow("Quote Console - YJ Energy").SwfTable("SwfTable").Exist Then
 msgbox "yes"
 cnum = SwfWindow("Quote Console - YJ Energy").SwfTable("SwfTable").GetTOProperty("ColumnCount")
 rnum = SwfWindow("Quote Console - YJ Energy").SwfTable("SwfTable").GetTOProperty("RowCount")
 msgbox "columns: " & cnum & " , rows: " &  rnum
Else
 msgbox "no"
End If
The result was: QTP was able to recognize the SwfTable object (the "yes" msgbox popped up), but the column and row counts were returned as null (see image).
I can't attach images to this posting. Every time I tried, it crashed the browser (FF or IE), I will try to attach them later...
Any idea?
  • 7695
    Hi Xyin,
         You didn't specify what control that you were using, but I guessing it was an UltraGrid. In which case you can use SwfTable("SwfTable").RowCount and ColumnCount respectively. As to GetTOProperty that is a QTP method so I cannot comment on it in too much detail, but it seems to get a property value off of the test object. The UltraGrid does not have either RowCount or ColumnCount as a property directly off of the control.
  • 65
    I still can't insert or attach (under the Options tab) an image to the above post. My browser kept getting closed when I tried to do that.  :)
