I've started a new thread because the title of the old one became incorrect.
I need to use TestAdvantage 7.1 CLR2
Trying to install with QTP V10 gives an error
Which (presumably earlier) version of QTP is compatible with this version of TestAdvantage?
Go to TestAdvantage FAQ page: http://ko.infragistics.com/faqs/testadvantage.aspx and follow the steps described under "Installing older version of TestAdvantage on QTP 9.5 and later"
That should help you install TA 7.1 on QTP 10
Ammar
Hi Ammar,
Thanks for the reply, I tried what you suggested, now when I try to install TestAdvantage 7.1 CLR2, I get a different error:
Mercury Interactive QuickTest Professional Version Check
Fatal error found
The registry was checked to verify that your installed MercuryInteractive QuickTest Professional and .NET Add-in were version 8.2or greater.
It appears that the registry entries were not found or your version isincorrect.
QuickTest Professional Version = 0.0QuickTest Professional.NET Add-in Version = 9.2
Please re-install your Mercury Interactive QuickTest Professional and.NET Add-in and then re-run this installation.
(The error I had before was:
QuickTest Professional Version = 9.5QuickTest Professional.NET Add-in Version = 0.0)
Ross
I just tested this on my Win XP VM and it worked fine! Is your machine a 64-bit machine? What is the OS type?
