Hi -
QTP identifies the Infragistics.Win.UltraWinDock.FloatingWindowContainerEx object in my application as a SwfWindow. Due to the way our automation framework is built, we use Win32 APIs to identify the windows present on the desktop and once we have identified our desired window using the title and window class, we set the context to this window.
The problem with this object is that the "regexpwndtitle" and "text" property of this object is blank and the developer cannot find any of the above two properties listed to pass in the title of the window.
Is there a way to set any of the properties for this object such that QTP can populate these properties?
Let me know if you need more clarification on this.
Unfortunately to my knowledge, I don't believe there is a way to set either of those properties. As this is more of a NetAdvantage development question, perhaps you may have better luck finding an answer on that forum.
