Good afternoon,
In our applicaiton we select tabs and enter data. Once we finish entering the data, we need to close the tab with QTP to retain the values. Once we save the record, the value are save with it.
Here is the select tab.
SwfWindow("Summit FT - Generic Asset Definition").SwfTab("_tabControl").Select "Trade Envelope"
How do we close the tab using test advantage? Is the documentation for the commands by object available for test advantage as a referance.
Brian
If the TabControl in question is either the UltraTabControl or UltraTabStripControl then you can use the action CloseTab which should be in the intellisense for the control and in the documentation. So for your sample it should be:
SwfWindow("Summit FT - Generic Asset Definition").SwfTab("_tabControl").CloseTab "Trade Envelope"
