Good afternoon,
I have a menu which has child menus that I have already built a functio work with. I now need to go 1 more level deep. Below is the code for the function and the calling code. I need some help on line 183 which is the last code to get the 3rd level menu.
Menu / Item 1 works with existing funciton
Menu / Item 1 / SubItem 1 I cannot get past the error on line 183 see code below.
Brian
Set objectMainPage = SwfWindow("Summit FT - Bond Definition")
'Process the selection of Bond Definiton, Analytics, Details... from the menu'Build up the menu code here to select from the menusSet objectToolBar =objectMainPage.SwfToolbar("_toolbarsDockAreaTop")specifiedToolBar = "Desktop Menu"specfiiedToolBarMenuItem = "Bond Definition" 'This is what the text that you see is without the shortcut keybonspecifiedToolBarSubMenu = "Validate" 'Text is case sensitivespecifiedToolBarSubSubMenu = "Details..." 'Text is case sensitivenameToolBar = "" 'Toolbar namenameToolBarMenu = "" 'Toolbar main menu itemnameToolBarMenuSubMenu = "" 'The submenu namenameToolBarMenuSubSubMenu = "" 'The submenu nameobjectToolBarSubSubmenu = "" 'The object to recieve the subsubmenu object for validation of enabled etc properties in the calling scriptreporterDetailsFuncSelectToolBar = ""'Get the toolbar text/name with the toolbarbutton text/nameeventCodeFuncSelectToolBarMenu = CommonTMSSelectToolBarMenuItemTwoLevels(objectToolBar, specifiedToolBar, specfiiedToolBarMenuItem, specifiedToolBarSubMenu, specifiedToolBarSubSubMenu, nameToolBar, nameTBarItem, nameToolBarMenuSubMenu, nameToolBarMenuSubSubMenu, objectToolBarSubSubmenu, reporterDetailsFuncSelectToolBar)If eventCodeFuncSelectToolBarMenu = 0 Then 'Click on the menu item by opening the dropdown and then selecting the submenu objectToolBar.DropdownToolbarTool specifiedToolBar,nameTBarItem 'Click the submenu item right afterwards or it will not work ***No Steping Though This one 'DropdownMenuTool "Desktop Menu,186:EntityView","197:Analytics" objectToolBar.DropdownMenuTool nameToolBar & "," & nameTBarItem, nameToolBarMenuSubMenu 'Click the subsubmenu item right afterwards or it will not work ***No Steping Though This one 'ClickMenuTool "Desktop Menu,186:EntityView,197:Analytics","208:Detail" objectToolBar.ClickMenuTool nameToolBar & "," & nameTBarItem, nameToolBarMenuSubSubMenu 'Check if the tab for the main page has the Asset Details TabElse eventCode = 1 eventLoopCode = 1 reporterDetails = reporterDetails & reporterDetailsFuncSelectToolBarEnd If
' @Function Name CommonTMSSelectToolBarMenuItemTwoLevels' @Description Select the submenu item from the menu item. We are matching based on the text displayed for the menu item not the recorded values' *******NOTE: you will need to get the toolbar name by recording the selection of a buttom and getting the toolbar name' *****************Example' SwfWindow("Summit FT - Calendar Definition").SwfToolbar("_toolbarsDockAreaTop").DropdownToolbarTool "Desktop Menu","57:EntityView" 'DropdownMenuTool "Desktop Menu,186:EntityView","197:Analytics" 'ClickMenuTool "Desktop Menu,186:EntityView,197:Analytics","208:Detail"' Toolbar = "Desktop Menu"'ToolbarMenu= "EntityView" ++++++++++++ We have replaced the compare based on the visible text to the user instead of the Key which is EntityView' ToolbarSubMenu = "Open"
'********************Menu Submenu Selection' Example if nameTBarMenu = "File" & nameTBarSubMenu "Open" we will open the dropdown Menu for File and then select the submenu Open item' @Documentation <objectPageToolBar> the toolbar control in the object repository for the page' @Documentation <nameSpecifiedToolBar> the name of the toolbar to find' @Documentation <nameSpecifiedToolBarButton> the name of the toolbar button to find' Returns:' <nameTBar> the toolbar text/name for selecting the button' <nameTBarItem> the toolbar button text/name for selecting the button' <objectTBarSubMenu> the menu object found for use in the calling script to check enabled and other status.' <resultDetails> the details regarding the function' <resultCode> the result code for pass or fail' Otherwise, the value of the NoData environment valueJim' Created: 04/25/2011 BLW' Last Updated:Function CommonTMSSelectToolBarMenuItemTwoLevels(byVal objectPageToolBar, byVal nameSpecifiedToolBar, byRef nameSpecifiedToolBarMenu, ByRef nameSpecifiedToolBarSubMenu, ByRef nameSpecifiedToolBarSubSubMenu, byRef nameTBar, byRef nameTBarMenu, byRef nameTBarSubMenu, byRef nameTBarSubSubMenu, ByRef objectTBarSubSubMenu, byRef resultDetails)' &&&&&&&&&&&& Note the values in the menu and compares are text and Case Senseitive. please insure you send in the value to match the menu item resultCode = 2 countToolBar = 0 booleanToolBarFound = False booleanToolBarMenuFound = False booleanToolBarSubMenuFound = False booleanToolBarSubSubMenuFound = False objectTBarManager = "" 'Temp destroy on exit objectTBar = "" 'Temp destroy on exit 'Set the toolbar manager based on the control from the page Set objectTBarManager = objectPageToolBar.Object.ToolbarsManager.Toolbars countToolBar = objectTBarManager.Count If countToolBar > 0Then For loopToolbars = 0 to countToolBar - 1 nameTBar = Trim(objectTBarManager.GetItem(loopToolbars).Key) If nameTBar = nameSpecifiedToolBar Then Set objectTBar = objectTBarManager.GetItem(loopToolbars) booleanToolBarFound = True Exit For End If Next If booleanToolBarFound = False Then resultCode = 1 resultDetails = resultDetails & " WE DID NOT FIND toolbar of: " & nameSpecifiedToolBar & " WE CANNOT SEARCH FOR THE MENU." End If Else resultCode = 1 resultDetails = resultDetails & " WE DID NOT FIND ANY TOOLBARS." End If 'Start looking for the menu if the assigned toolbar was found If booleanToolBarFound = True Then 'See if we can get the menu next countToolBarMenus = objectTBar.Tools.Count If countToolBarMenus > 0 Then 'Check the button and see if we can find the one we specified For loopMenus = 0 to countToolBarMenus -1 inStringToolName= "" textTBarItem = "" nameTBarMenu = objectTBar.Tools.GetItem(loopMenus).Key textTBarMenu = CStr(objectTBar.Tools.GetItem(loopMenus).CaptionResolved) stringHotKey ="&" 'Strip out the & key for the hotkey in the menu item instringLoc = InStr(1, textTBarMenu, stringHotKey) lenString = Len(textTBarMenu) tempStringLeft = "" tempStringRight = "" Select Case instringLoc Case 0 'Do nothing there is no hotkey specified for this item Case 1 'Remove the & from the front of the text textTBarMenu = Right(textTBarMenu, lenString - instringLoc) Case Else 'Build the string by gettting what is left of the & and then what is right of the & tempStringLeft = Left(textTBarMenu,instringLoc - 1) tempStringRight = Right(textTBarMenu, lenString - instringLoc) textTBarMenu = tempStringLeft & tempStringRight End Select 'Check if the displayed text matches the requrested menu item If textTBarMenu = nameSpecifiedToolBarMenu Then booleanToolBarMenuFound = True Set objectTBarMenu = objectTBar.Tools.GetItem(loopMenus) Exit For End If Next If booleanToolBarMenuFound = False Then resultCode = 1 resultDetails = resultDetails & " We found the toolbar of: " & nameSpecifiedToolBar & " BUTthe menu item of: " & nameSpecifiedToolBarMenu & " was not found." End If Else resultCode = 1 resultDetails = resultDetails & " We found the toolbar of: " & nameSpecifiedToolBar & " BUT NO MENUS WERE FOUND." End If End If 'Tool Bar found and looking for the menu 'Start Looking for the submenu item if menu found If booleanToolBarMenuFound = True Then 'See if the menu item has any submenu items countToolBarSubMenus = objectTBarMenu.Tools.Count If countToolBarSubMenus > 0 Then 'Check the button and see if we can find the one we specified For loopSubMenus = 0 to countToolBarSubMenus -1 nameTBarSubMenu = objectTBarMenu.Tools.GetItem(loopSubMenus).Key textTBarSubMenu = CStr(objectTBarMenu.Tools.GetItem(loopSubMenus).CaptionResolved) stringHotKey ="&" 'Strip out the & key for the hotkey in the menu item instringLoc = InStr(1, textTBarSubMenu, stringHotKey) lenString = Len(textTBarSubMenu) tempStringLeft = "" tempStringRight = "" 'Use case statement here to work with 0, 1, or else Select Case instringLoc Case 0 'Do nothing there is no hotkey Case 1 'Remove the & from the front of the text textTBarSubMenu = Right(textTBarSubMenu, lenString - instringLoc) Case Else 'Build the string by gettting what is left of the & and then what is right of the & tempStringLeft = Left(textTBarSubMenu,instringLoc - 1) tempStringRight = Right(textTBarSubMenu, lenString - instringLoc) textTBarSubMenu = tempStringLeft & tempStringRight End Select ''Check if the displayed text matches the requrested submenu item If Cstr(trim(textTBarSubMenu)) = Cstr(trim(nameSpecifiedToolBarSubMenu)) Then Set objectTBarSubMenu = objectTBarMenu.Tools.GetItem(loopSubMenus) 'Set the object only if correct object is found booleanToolBarSubMenuFound = True Exit For End If Next If booleanToolBarSubMenuFound = False Then resultCode = 1 resultDetails = resultDetails & " We found the toolbar of: " & nameSpecifiedToolBar & " the toolbar contained the menu of: " & nameSpecifiedToolBarMenu &_ " BUT the submenu of: " & namespecifiedToolBarSubMenu & " WAS NOT DISPLAYED. " End If Else resultCode = 1 resultDetails = resultDetails & " We found the toolbar of: " & nameSpecifiedToolBar & " the toolbar contained the menu of: " & nameSpecifiedToolBarMenu &_ "however, NO SUBMENU ITEMS WERE AVAILABLE." End If End If 'Start Looking for the SubSubMenu if we found the SubMenu item If booleanToolBarSubMenuFound = True Then 'See if the menu item has any submenu items countToolBarSubSubMenus = objectTBarSubMenu.Tools.Count 'Error Object doesn't support this property or method: 'objectTBarSubMenu.Tools' Line (183): "countToolBarSubSubMenus = objectTBarSubMenu.Tools.Count". If countToolBarSubSubMenus > 0 Then 'Check the button and see if we can find the one we specified For loopSubSubMenus = 0 to countToolBarSubSubMenus -1 nameTBarSubSubMenu = objectTBarSubMenu.Tools.GetItem(loopSubSubMenus).Key textTBarSubSubMenu = CStr(objectTBarSubMenu.Tools.GetItem(loopSubSubMenus).CaptionResolved) stringHotKey ="&" 'Strip out the & key for the hotkey in the menu item instringLoc = InStr(1, textTBarSubMenu, stringHotKey) lenString = Len(textTBarSubMenu) tempStringLeft = "" tempStringRight = "" 'Use case statement here to work with 0, 1, or else Select Case instringLoc Case 0 'Do nothing there is no hotkey Case 1 'Remove the & from the front of the text textTBarSubSubMenu = Right(textTBarSubSubMenu, lenString - instringLoc) Case Else 'Build the string by gettting what is left of the & and then what is right of the & tempStringLeft = Left(textTBarSubSubMenu,instringLoc - 1) tempStringRight = Right(textTBarSubSubMenu, lenString - instringLoc) textTBarSubSubMenu = tempStringLeft & tempStringRight End Select ''Check if the displayed text matches the requrested submenu item If Cstr(trim(textTBarSubSubMenu)) = Cstr(trim(nameSpecifiedToolBarSubSubMenu)) Then Set objectTBarSubSubMenu = objectTBarSubMenu.Tools.GetItem(loopSubSubMenus) 'Set the object only if correct object is found booleanToolBarSubSubMenuFound = True Exit For End If Next If booleanToolBarSubSubMenuFound = True Then 'Report we found the submenu item resultDetails = resultDetails & " We found the toolbar of: " & nameSpecifiedToolBar & " the toolbar contained the menu of: " & nameSpecifiedToolBarMenu &_ "and the submenu of: " & namespecifiedToolBarSubMenu & " but the sub submenu of: " & nameSpecifiedToolBarSubSubMenu & " WAS DISPLAYED. " Else resultCode = 1 resultDetails = resultDetails & " We found the toolbar of: " & nameSpecifiedToolBar & " the toolbar contained the menu of: " & nameSpecifiedToolBarMenu &_ "and the submenu of: " & namespecifiedToolBarSubMenu & " but the sub submenu of: " & nameSpecifiedToolBarSubSubMenu & " WAS NOT DISPLAYED. " End If Else resultCode = 1 resultDetails = resultDetails & " We found the toolbar of: " & nameSpecifiedToolBar & " the toolbar contained the menu of: " & nameSpecifiedToolBarMenu &_ "and the submenu of: " & namespecifiedToolBarSubMenu & "however, NO SUB SUBMENU ITEMS WERE AVAILABLE." End If End If
Set objectTBarManager = Nothing 'Temp destroy on exit Set objectTBar = Nothing 'Temp destroy on exit Set objectTBarMenu = Nothing 'Temp destroy on exit CommonTMSSelectToolBarMenuItemTwoLevels = resultCodeEnd Function
Hello QTP11_User
I suppose that this forum thread is duplicate with https://ko.infragistics.com/community/forums/f/test-automation-for-micro-focus-uft-wpf/78818/qtp11-does-not-record-the-menu-actions/398297#398297 . To be easy to follow your request, please write in your own thread https://ko.infragistics.com/community/forums/f/test-automation-for-micro-focus-uft-wpf/78818/qtp11-does-not-record-the-menu-actions/398297#398297
Let me know if you have any questions
Regards
FYI we wil create a CASE for HP to download the QTPNET_00116 HOTFixe.
I'l feed you back if the problem Persist.
Thanks Alan for your reactivity.
The 64-bit application for QTP11.0 support is explained by HP in this topic. http://support.openview.hp.com/selfsolve/document/KM202273
This KM talking only about QTP_00699, that i already install (with 2 other PATCHs QTP_00709 + QTP_00925) + One RRV_xx for result viewer.
I do i search in HP Site and did not found any QTP_00116 or QTPNET_00116 to download.
Please where do i can fiund theeses patchs ?
Are they any where on ftp site in your side where i can download them ?
Thanks for your help.
What patches do you have installed for QTP?
Make sure you have QTP_00116 as this is needed for 64 bit testing. Also if your application under test is targeting .NET 4.0 or you have Windows 7 SP1 installed then you may need to install QTPNET_00116 as that addresses issues with .NET 4.0 and Windows 7 SP1.
Let me know if you have any questions with this matter.
Haï
What was the issue for the question befor ?
I have the same error onD ropdownToolbarTool' "Object doess't support this property or method 'ObjMenu.DropdownToolbarTool Toolbar,Menu1'
Example : ObjMenu.DropdownToolbarTool "Desktop Menu","11:File"
This error produce on windows 7 / 64 bits but does not produce on Windows XP SP3 / 32 bits.
I'm in TA 2011 Vol2 for QTP 11.0
