Hi ,
We have a toolbar which has the following types of toolbar items
1) Toolbar menu option with child items which can selected by clicking on the drop down arrow
2) Toolbar menu option without any child items
what we have observed is TA is unable to reccord on toolbar item 1 but able to reccord on toolbaritem2.
I have attached a screenshot with Toolbar object and QTP statements in it..
Any ideas why TA is behaving this way ?
Vijay
Hi Dave,
Thanks for the response. Is there any tentative date for this fix as this issue is marked as critical on our side ? and also Can I setup an alert to notify when the fix is released ?
Regarding the workaround, I did already try it out but it fails during the re-run. I can do a webex to show you the issue. Please suggest a convienient time.
Hello Vijay,
This is actually a known issue with 2010.3, and a resolution for the issue will be released shortly. In the meantime, you can record a dropdown action on the PopupMenuItem, and replace the "tbmgrDropDown" parameter value with "tbmrClick". It will then replay as desired.
hi Dave,
We need a solution to the TA 10.3 version as we are not sure when the dev team would upgrade to the 2011 volume 1 version. It would therefore useful to get a defect fix for TA10.3 version to get us going and resolve the immediate issue.
I reproduced your issue using my own sample and NetAdvantage 2010 Volume 3 and TestAdvantage 2010 Volume 3. Just to be thorough, I upgraded the sample to NetAdvantage 2011 Volume 1 and used TestAdvantage 2011 Volume 1. After doing that, the issue no longer occurred. It appears that the issue was resolved in the latest version, but the resolution was never backported to the older versions. I will talk to our Engineering department to see if there was a reason for this.
Looking forward to the resolution Michael. This issue has blocked many of tests being developed , it would be very useful to understand the cause of this.
ThanksVijay
