TestAdvantage ver 2010.3,
Following code is not working
'Get the list of items in the toolbar tlbContent = SwfWindow("Microsoft TaskVision 1.1").SwfToolBar("tbrTop").GetContent
'no. of Items in toolbar
cItems = SwfWindow("Form1").SwfToolBar("Formatting").GetItemsCountSwfWindow("Form1").SwfToolBar("Formatting").GetItem(index)
Also not able to find out one of the toolbar button ENABLED or DISABLED property value with GetItemProperty.
As Button click Record-Playback code gives this for Toolbar
PerformToolAction tbmgrToolbar, tbmgrClick,tblbarname , btnName
There should be equivalent code for operations - GetItem(), GetItemsCount, GetContent, GetItemProperty
Pl advice on this.
~Laxmikant.
Ravi,
I answered your question here.
Hi Michael,
I'm not able to find the valid key from the toolbar, could you please help me out with it.
SwfWindow("window").SwfWindow("window").SwfObject("_TempBlotter_Toolbars_Dock_Ar").GetItemsCount("Refresh")...this throws an error saying "key not found".
I'm using TestAdvantage 2006 CLR 2.X version 3....
Ravi Salunkhe
The GetContent method takes a string for the key or a number for the index of a toolbar and returns the captions of the tools within the toolbar in a list that is delimited by a new line. You seem to want to access a tool on a child menu which is a popupmenutool and not a toolbar, so I don't think the GetContent method will work for you. Please tell me exactly what you want to do with the child menu so that I can address your question.
Hello all,
Could you please clarify, how can I use GatContent method to the child menue item?
Please, refer below:
"Editors" should be the key of the taskpane toolbar.
