Following is the code (Recorded, the menu click -> sub level Menu click -> Menu Item click)
.SwfToolbar("_Main_Toolbars_Dock_Area_To").PerformToolAction tbmgrToolbar, tbmgrDropDown, "tlbMainMenu", "Asset" .SwfToolbar("_Main_Toolbars_Dock_Area_To").PerformToolAction tbmgrMenu, tbmgrDropDown, "tlbMainMenu,SubMenu", "SubLevelMenu" .SwfToolbar("_Main_Toolbars_Dock_Area_To").PerformToolAction tbmgrMenu, tbmgrClick, "tlbMainMenu,SubMenu,SubLevelMenu", "NewMenuItem"
While playback, it throws an error Object is not visible
as after clicking the first menu , it tries to find the sub menu (by that time) the clicked first level Menu disappears.
How to hold off the display of First level Menu, so it can click the second level menu?
I've to click the Menu item which comes after clicking 1st Menu bar Option 'File' and then 2nd level menu option 'New'.
Pl sugggest me the solution.
Thx in advance,
~Laxmikant
Thanks for the update. I'll wait for you to test my sample.
Thanks for the ZIP file. I've not completed yet. I will let you know asap I finish this task.
Did my sample project help you resolve your issue?
I've attached my sample project. I created it using NetAdvantage 2011 Volume 1. If you're using a different version, just run the project through the NetAdvantage Version Utility or Project Upgrade Utility before opening it with Visual Studio.
Our dev have netadvantage installed, I can install NetAdvantage.
Pl provided me the Sample Project, so I can utilize the same.
